Well for various reasons (one being constant random blue screens) I decided to format and reinstall windows last night.
So I open up the box, disconnect all storage drives put in the windows installation CD and start, use the usual settings after it's done copying files it blue screens.... so I shut down and retry the whole thing again, and blue screen after the copying files portion again...
First test, memory.... ran memtest86 and it had an error on test 4. I took out both sticks and one of the gold connectors on one of the sticks looked burned. so I put that aside inspected the other one and put it back in the system. Started the windows installation and crashed in the same spot.... so I thought maybe I put the memory in the slot that the burned stick was in so I put it in the other spot and ran memtest86 and it passed 4 full test passes....started windows installation... blue screen in the same spot.
Second test, hard drive - made a wd diag tool CD and did a quick scan - no errors, did a full scan - no errors.
Third test, one of the PCI devices... i took out all PCI devices.... try again and blue screen on the same spot once again....
Fourth test, video card - so I switched video cards with my bro's comp.... try to install again and once again blue screen in the same spot.
At this point the only thing i can think of doing is taking everything out of the system and trying the install as bare as possible... any thing you guys suggest?
Specs:
Antec NeoPower 480 PSU
Asus A8V Deluxe w/ 1014 bios
AMD x2 3800
1 (1 bad) CMX512 3200C2 512MB
nVidia 6800GT - (both mine and my bro's)
WD 74GB Raptor
Specs:
AMD x2 3800
WD 74GB Raptor
