Im a n00b its ok!
Ok, so i hear a whole lot about AA and AF is it? ansiotrophic and antialiasing that stuff......ok so i look in color managment and dun see it......is it only for lcd's or what? im on a 9600 pro, curious as to what i should put mine at if i can even mess with those things color managment just shows a place to add a profile, not to change anything :confused: and if anyone can explain what they do/are would be greatfull :)
n00b flames are welome :p
soulsaver_8229
and how will i know if my 9600 pro will fit the bill of having those features? :p
ok just found out where the are..........but what kinda settings am i looking for? i just play halo really......would it look better doing any like web surfing or such?
soulsaver_8229
Generally no, your video card should handle any AA on websites fine. I'm not an expert, so I can't tell you much.
As for settings on Halo, you should go from the lowest setting to the highest and deduce your own conclusion on the most playable setting.
i see i see, so really i shouldnt mess with it, well thanks for the links seems like somthing only heavy gamers should mess with, thanks much :)
soulsaver_8229
soulsaver_8229
No, if you want better images in games then you should increase them as much as possible. You will notice a big difference in games when applied.
well, then i have a question, what should i put them at for Halo? i run 1024x768
soulsaver_8229
test it at every resolution til u find the best one? ;)
well figured there is a sweet spot for everyone in all games......sorry i understand what those settings are but didnt know they had to be customized per person, thats all :p
soulsaver_8229
Don't use AA and AF in Halo. Halo uses a type of rendering that makes AA and AF useless (which is a real shame because the game could seriously use a little AF).
I think that you can enable AF, but you will get artifacting (funky shadows everywhere). At least, that's what I noticed.
yeah i just messed around with it, nothing big, plus i kinda keep low settings on Halo, dont perfer most of the details, plus im in 1024-768
soulsaver_8229
