Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
A good idea would be to take like 5 pennies, one and put it flat on the chip, then put adhesive on the rest of them so that they stand straight up(maybe a tiny drop of superglue as well to make sure they dont fall onto the card itself. It would work just like a normal heatsink instead of just stacking them. Not sure if this will work better, but I would imagine so.
Notice : JUST A THOUGHT!! I take no responsibility if someone owns there card because of this! Also, if you DO attempt this, I would soke the pennies in orange cleaner or alcohol or something. Doubt you wanna smell burning crud after using dirty pennies for a few hours, lol.
