I'm a bog dummy but
crewzen
So I'm not too bright, but I need some input just like 5 alive.
Input that is what my new 3870 is doing with the card from the back of the computer. I thought that the card would suck in fresh air from inside the computer and exit the hot air out the back exit where it normaly exits all the other cards and psu?
But no it is pulling air in through the vent in the back where all my hot air is, I normaly suck air in through the front and exit out the back and top.
So Is in the back of the graphics card normal or am I going nuts.
OH I'm there already but still need input.
Thanks in advance.
If your card has a blower on it( the card is sealed with a duct leading to the back) hot exhaust will come through the rear.
NO the fan motor is running backwards. Pulling air in from the rear, so if you have a hot running card check that the air is comming out of the rear. If not guess what.
wrong way has struck again.
Sapphire also said it should be blowing out the rear. I got a dud. Mine REALY sucks. Literaly. ha ha ah so.
