Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I've never used the ignore list before, but I've finally found a reason to.
I'd just like to know how it works. I assume I won't be able to see the person's posts, but will they see mine? What if I create a topic? Can they post in it?
If you add someone to ignore list - nothing changes for them, only for you.
Posts from users in your ignore list will be replace with text "this is post from ignored user XYZ", and you can see his post if you click on that text.
If someone quotes user from your ignore list - you will see his message (only inside quote, posted by other user).
If user from your ignore list made a thread - you will see thread, but inside thread this user posts will be hidden by default (including first post).
