Oct 13, 2006 #1 P pebbles n00b Joined Dec 19, 2005 Messages 52 Directing airflow vertically from a fan to the top or the bottom (pcb side), which one would be most effective in cooling hard drive. In my situation, horizontal air flow (end to end) is not an option..
Oct 13, 2006 #2 A Arcygenical Fully [H] Joined Jun 10, 2005 Messages 25,066 The PCB side is the side that produces most of the heat... I'd go for that one .
Oct 14, 2006 #3 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Yep, definitely the bottom. That's where all the circuitry that needs to be cooled down is.
Oct 14, 2006 #6 A Arcygenical Fully [H] Joined Jun 10, 2005 Messages 25,066 You can aways do what I did, flip it so the PCB side is facing up, convection really helps cool those things off without any fan support. But, um... dont have a water leak on it
