If you can solve this problem, I'll be amazed.
have2p
Abit AX8 w/ A64 3000+
Seagate 7200.7rpm 80gb SATA drive
The motherboard does not detect the hard drive in BIOS. Under the hard drive priority list( in the boot devices menu), there is a hard drive listed as SCSI-0 the name of the drive (ST4373497 or something similar). When I turn off the RAID controller, this SCSI-0 drive disappears from the list, leaving only "Bootable Add-In cards." When the bios tries to boot from this mysterious SCSI drive, it says that there is no boot device. Windows XP setup says that it cannot detect any hard drives.
When I press tab to access the raid controller menu, it detects my hard drive, gives me the name, serial number, and capacity. All the data seems accurate. It sees that its an SATA drive and says nothing about SCSI. I only have the one hard drive, though, so I can't setup an array of any kind obviously.
So I figured either the motherboard has an issue or the hard drive is defective...
I tried all four SATA plugs on the motherboard, same results from all. I then plugged in a 36gb Raptor SATA to the motherboard and it was detected and booted from without issue. So the motherboard is not defective because it can detect and boot other hard drives.
I put the Seagate into another computer and it was detected without issues. I formatted it, installed windows on it, and booted from it. I then put it back into the computer with the AX8, and it still is not detected.
I have flashed the BIOS to the latest version, same results.
I have disconnected all unecessary hardware (cd rom drive, floppy drive) and disabled any com ports and serial ports that I didn't need to free up IRQs... same result.
Is there some sort of incompatibility with the drive and the motherboard? I've tried everything I can think of. It makes no sense to RMA the board or the hard drive because they both work perfectly on their own, they just don't work when together. Strangest problem I have ever seen.
I suppose if you guys can't fix it I'll just refund the drive and pickup a Western Digital or something.
Thanks for your help.
well, you could really narrow it down if you had another SATA drive handy.. because its one or the other.
Install windows on the other drive and put the seagate drive in the system as a second drive, see if it functions properly as a secondary after windows is installed.
I don't have any experience with that board but: Is it one of those RAID controllers where you have to go into the RAID controller firmware (kind of like the BIOS, but it is specific to the raid controller) to configure the hard drive? In most SCSI RAID controllers, you have to hit something like cntrl-a to get in and create an array, then add the disk to the array, and then make sure you load the RAID controller drivers during the XP setup.
Hope that's some help.
in standard cmos features go to ide channel 1 master and make sure everthing is set to auto
Have you tried defining an array with the single drive in the raid controller bios? I know that's what I had to do with my NF2 board w/ a promise sata raid controller. It only gave one option for the raid array (0+1 for some reason), but when I defined it, windows setup would detect the drive with no problems as long as the controller drivers were slipstreamed in textmode (no floppy drive), and it would have no trouble booting off of it.
I have the EXACT problem.
Two motherboard and two SATA drives later no go. What the fuck?
My 36GB Raptor from my other machine boots just fine. No go for this machine. Any help?
eag
Seatools doesn't detect the drive either. It's a 300GB drive.
Just taking a wild guess, but could it be a misplaced jumper on the motherboard or hard drive? I know jumpers always used to screw me over.
