It's actually smaller than 80mm. I have an 80mm fan and it's too big for it.
I have a Dynex case that I picked up for really cheap a while ago. http://www.dynexproducts.com/p-276-dynex-atx-mid-tower-case-black.aspx
Also, as the specification say, there is space for two optional 80mm fans on the inside in the front of the case. However, the front is entirely closed, what good will those fans do? Just provide better airflow inside the case?
Weird. Are you sure you have an 80mm?
It probably pulls the air up through the bottom of the front panel. There's a lot of cheap cases that do that.
I lifted it up today and looked underneath, it's all sealed up too. Would having 2 fans in the front provide better airflow within the case? Blowing the air towards the rear exhaust fan?
