If a psu is completely dead..
Piph05
If a psu is completely dead does that mean absolutely nothing will attempt to turn on, not even lights. I ask this because i believe i have a psu that i believe is completely dead. I have browsed the internet and some people have had psu problems but the lights on the front of the computer still turn on. This isnt the case with me, nothing turns on, which is why im curious and hoping this isnt a motherboard problem also.
The psu is an Antec SP 2.0 500w. I have narrowed it down to the psu being completely dead because i have removed hardware and it wouldnt start up, the fan inside the psu will not even twitch when turned on and i have read that the Antec SP 2.0 suprisingly have been known to fail. I should also add that when i plugged the power cord into the psu a slight buzzing sound came from it, which then after i believe caused the computer to not boot, even though it was working fine 2 hours before. I should also mention that i have tested the power cord on another computer and it worked.
From what ive said here does this sound like a psu problem? I am thinking/hoping it is just the psu and nothing else. I would also rather not try to jump start it due to the fact of voiding my warranty. If someone could let me know what you think that would be great. Thanks.
Go ahead and try jumping it.... that won't void your warranty and should give you a definate answer as to rather it's dead or not.....
