IEM (with mic) to PC
Serville
Hi,
I have Soundmagic E10M IEM with microphone, and i"m thinking of using it with my desktop PC for gaming & chatting. I have already got several headsets, but I find them uncomfortable to the ears after long hours.
I know I'm going to need a splitter for Audio & Mic, something like this:
http://www.showmecables.com/product...TRRS-Jack-to-Dual-3-5mm-Stereo-Plug-6-IN.aspx
The problem is I couldn't find it in my country.
The best I could find is this :
http://images.monoprice.com/productlargeimages/56131.jpg
Product description : " 6inch Premium 3.5mm Stereo Female to 2 x 3.5mm Stereo Male (Gold Plated)"
The connector looks the same, but it doesn't specifically say for Mic & Audio.
Are they electronically different ?
Thanks
Hi,
Thanks
The one from monoprice is probably just a splitter.
You need something that takes the T R R S connector and takes that to 2x T R S (Tip Ring Sleeve) connections.
What country are you in?
I got one here in Sweden without issue.
I'm in Jakarta.
The only cable I could find is Audio/Mic Splitter from Razer, but it costs $19 which I think completely overpriced for such a cable.
