IEM for ~$50
siluro
Looking for a pair of IEMs, wondering if anyone can share some I should consider.
So far I've been looking between these 3:
VSonic VC02 ($45)
Astrotec AM-800 ($45)
Astrotec AM-900 ($50)
If you have any experiences with the above mentioned IEMs or others that fit my budget let me know of any recommendations you may have to make.
i have the v-sonic gr02 bass edition. bought them from lendmeurears.com off recommendations from head-fi. all i can say is they sound a lot more expensive than the ~$35 i spent on them. build quality is fantastic. clear mids, controlled bass and good soundstage. if you order from that website they also give you a bunch of ear tips. not sure if you can beat this sound at under $40.
I have a pair of Klipsch S4A's you can have for $20.
Selling because I'm now the very happy owner of Vsonic's GR07 MKII.
I would consider the GR04s except I probably should have mentioned I do not want an over the ear style.
