IE changes Resolution
csledd
Hello all. A client upgraded their standard full screen monitors to two new 24" widescreen monitors. They have them running at the max resolution which is in widescreen at 1920x1080. When they open Internet Explorer the resolution changes to what was used on their old monitors and back to fullscreen instead of widescreen. Any suggestions to fix this issue? We have already uninstalled IE8 and disabled Add-ons and reset IE settings.
Uninstall old display drivers and install drivers for the current displays. Actually this should happen automatically, but make sure. IE has nothing to do with screen resolution. check the advanced settings for the graphics card in CCC or nVidia control panel.
Good luck
Dave
