Manny Calavera
- Jun 10, 2004
Well,after sitting here wondering why my newer Ultima 90i's are not cooling properly it occured to me that maybe,just maybe they were not mounted properly....
So,I need to know,before I rip two new builds apart to fix what may noy be broken can someone here tell me what the O-Ring is for in this diagram and what it does ? I know I did not install them properly,and I think that one of them on the four corners was not installed at all.What do they do ? and would the lack of them in a mounting install for a U90I explain a 8 to 10 celsius rise in idle temps ?
Instead of putting them on the 775 Pillar,I simply placed them on the mobo,laid the backplate on top,and then slid the pillars into the mounting plate holes,held on for dear life,flipped it over and placed the 775 bracket mount on,then proceeded to frustrate myself to NO end,by trying to screw in the bracket mounts,as of course the o-rings kept dutifully falling off and onto the floor.
This in a Asus PBK-E with Q6600 g0,in a new Lian Li PC65B with 2 80mm 36cfm panaflos in front(on high) a 80mm stock case fan in back,and a few Vantec 80/92/120mm adapters on the way + 92mm Zalman F2's,so that I can mount some higher rpm/cfm 92mm's in the back and top blow hole,should help,but I still somewhat confounded at the huge rise in cpu temps.The sink that was on this chip before was a Thermaltake V1.It gave me idles of 39c and loads of 65c with p95 25.4 blends.
I have re mounted three times,in two days,and re cleaned the cpu,re apllied with AS5 and ICD7,temps have gone from idles of 55c to 52c to finally 49c,all with the same ambients.
Help !!
Help !!
