identifying PCI slots
mikeblas
[H]ard|DCer of the Month - May 2006
I know there are 3.3v- and 5v-only PCI slots. Plus, 64-bit and 32-bit slots. And I think there are 66 MHz and 33 MHz slots.
I've got an older system, and would like to see if I can use it. I'll have to shop for a PCI video card, and a PCI SATA RAID controller. How can I identify the slots on the motherboard, as well as the keys on the card edge, to know what cards will work, or what type of cards I need?
I guess I'm looking for a chart that shows all the different keyings. Does anybody know of one?
.B ekiM
Google is your friend.
PCI slotsand cards.
Hope this helps.
Luck.......... :D
Trust me, it's not like I didn't try searching for it myself.
Tigerbiten said:
Afraid not. This is one of the sites I came across when I was trying to cover it myself. On a couple of the pictures, I think they've confused 5v-only and 3.3v-only 32-bit slots.
I also found the PCI Sig, which I'm sure would answer my questions. But they require membership ($3000/year) or purchase ($100/set) for the documents, and I can't quite justify that.
I found this site, though, which has a clear and concise illustration that correctly shows the different keyings.
.B ekiM
