ideas
ocphangaz
my current fan configuration in my casing...
front bezel, 120mm 93CFM sucking fresh cool air from outside
5.25" bezel modded to be exhaust for the excessive air intake...
rear, 1 60mm 40CFM to suck air from outside towards the vid card
rear, 1 duct for 92mm delta 110CFM intake to CPU
PSU exhaust
so.. this been lingering in my head for few days... what if i set the 110cfm as outake and exhaust through the rear ?
currently i have system temp problem, where it'll start from 30C.. and goes up until 38C, compared to the CPU where it stays at 42C.
the only thing you're using for exhaust is the PSU?
5.25" bezel modded to be exhaust for the excessive air intake...< I'm not sure I understand what you're saying here. the front of your case is acting as both an intake and exhaust?
a blowhole fan(top of case) would help quite a bit.
