Right now i'm running (see sig) @ just under 2.8ghz(2796mhz) w/ a 233 mhz fsb w/ my ram at 1:1, so its definitely running over its spec speeds(see sig). I cant OC much further w/ speeds FAR below spec speeds let alone current ram speeds.
I am running these speeds right now because i can't really get much higher for whatever reason, even running my ram in single channel or just 1 stick alone, both OC to the same point. I cannot get my FSB over 240 regardless of the setup, i can hit 244, but prime95 gives me errors, and i had a few random reboots. [edit---when playing a game for 30 minutes, game would hang, then reboot when trying to exit the game.]
have tried:
setting multiplier to 1:1, 5:4, 3:2.
changing ram voltages from 2.55-2.85.
even tried upping CPU voltage a little.
disconnected all hardware i don't need.
disabling spread spectrem+everything else in bios.
ram timings, a lot of them.
i'm thinking that my ram is limiting me?? but it does not make sense if i can run a 233 fsb at 1:1 w/ 2.65v when i can't run a 3:2 w/ the FSB increased by another 7 mhz even on 1 stick of ram in single channel. the only other alternative is power, but 420 watts is more than enough, but w/ a random reboots after a 240 fsb worries me in that department. temps are well within spec even w/ case fans off, doubt its heat.
also. i can stick in a stick of mushkin lv 2 an hit a 240FSB. i haven't done much tweaking in the past few months b/c i've been busy, but it bugs me that i can't even get close to a 250 FSB in a stable environ ment.
edit: another important thing is it'll post w/ a 245fsb, but when it is loading WinXP it will hang. a few times it has rebooted at this point.
hope that mumbo jumbo makes sense to somone and i can be helped to push it further.
w/ search disabled and after a couple hours of searching today alone, no luck.
have tried:
