ideas needed for liquid cooling setup
fadz
well iv worked out the motherboard il be running,and it will be the DFI Lan Party p35 dk series,il be running a q9550 cpu,now i just want some ideas on what liquid cooling gear i should go with,$$$ isnt much of an issue,i basically want the best of the best as il be doing alot of overclocking and benchmarking,cheers.
If you want water, you're in the wrong subforum.
If you want sub zero loaded temperatures (which a normal water setup will never provide) you need to look into phase change cooling.
If you want sub ambient loaded temperatures (but not below freezing) you can use a TEC setup (I wouldn't, not for a Quad core Intel) or get a chilled water setup.
The ball is in your court ;)
