What OS, OP?
I don't think that's been asked or posted here.
If Server 2008 or greater, I've never had an issue expanding and shrinking partitions from within Windows. Good possibility that you won't need a 3rd party partition utility.
He has a 3TB array. He's not low on disk space. This is not the appropriate solution.
I've never had a problem before either... but yet he insists he can't do it.
I missed that part.... why on EARTH would someone use a 3TB array and only leave 40GB for the system drive? Absurd.
j sta is correct there is no unallocated space between c and m. BTW its running server 2012 standard, Also i have to go there tomorrow so I will get screenies of everything. Been burning the road up so far this week and havent been able to go by. Also big thanks to everyone who has tried to help so far. Much appreciated guys
ok i got a couple pics there this afternoon. One shows the c and d drive (disregard M in the earlier posts) and the other shows that i cant extend c. I had been working on another box that had an M drive so i had that on my mind when i posted. Sorry
img]http://i.imgur.com/lXIdcpY.jpg[/img]
img]http://i.imgur.com/kGpc64r.jpg[/img]
It is most likely because there is no unallocated space between the C: partition and M: partition.
A partition cannot extend between 2 separated parts of the disk/array, as seen in disk management mmc. Unless it's a dynamic disk I think? But even if so, certainly not best practice.
Hence why I asked to see a screenshot of diskmgmt
Chances are, he will just need to do some partition juggling to get the OS partition extended.
Shrink M: partition just enough, so that unallocated space will be just big enough to create a new partition for all the data from M:.
Create new partition in newly unallocated space.
Copy data from M: to new partition, let's call O:
Delete M: partition
Extend C: partition to, say, 100 gigs. 60 would probably suffice, but be safe.
Now recreate M: partition in the current unallocated space.
Copy data back from O: partition to newly created M: partition.
Delete O: partition.
Extend M: partition.
