Ideas? Chieftec Case - Watercooling?
noteworthy
I have a used chieftec case I ran across that needs some work.
My thoughts are to mount one of my 360 Black Ice Radiators on top by adding one more 120mm hole up top. The other radiator either mount in front of the case and cut out three holes. Move the hard drives to be mounted on the bottom of the case or on the back panel behind the PSU.
I could also try to stack the radiators but the outlets would be too close unless I built a shroud. In that case the power supply would have to be turned flat for enough room.
Ideas?
http://www.quagmiresloveshack.com/traustic/casework/100_1227.JPG
http://www.quagmiresloveshack.com/traustic/casework/100_1229.JPG
how do I repair this?
http://www.quagmiresloveshack.com/traustic/casework/100_1228.JPG
1 360 rad on top, and 1 240 rad @ front. place the HDD's in the 5,25 bays.
how to repair ..dunno
