AMDisSWEET
- Sep 6, 2002
I have a Antec 300 with just the two stock fans that came pre-installed. The noise level from them is acceptable. I just recently put in a AC Freezer 7 Pro and its a bit louder than the stock cooler but the noise level is in line with the stock fans and the increased cooling is more than worth it.
I was originally planning on just putting in a side fan mostly to reduce the amount of dust that is pulled into the case from the top and rear fans. They seem to draw air from the side panel which has no filter.
If anyone here has this case I would appreciate some feedback as to how well an exhaust fan on the panel works. I was thinking I might put in a 800RPM Sycthe or the slowest Yate Loon. My concern is that it won't have enough power to take air out of the case and repel the dust and that a higher CFM fan might 'steal' air from my upside down PSU.
Thanks!
Thanks!
