So I have this idea based on the appearance of 170mm long gaming graphics cards. It'd be a cube, the longest edge just enough for a two slot card which comes around 230mm, the next edge is 180mm and the height is 130mm.
Above the ATX shield I would put two 80mm fans. The front of the case I would also put two 80mm fans as low as low profile RAMs and the 24 pin connector allows (provided that connector is on this edge but that's likely).
Now comes the fun part, the PSU. Take a Flex ATX PSU and put it on the roof of the case in parallel of the two 80mm fans. Now you can remove the 40mm fan from it. If you look at http://www.hardwaresecrets.com/article/Athena-Power-AP-MFATX40P8-400-W-Power-Supply-Review/1486/2 it's quite visible that the PSU itself doesn't need to be 150mm long, you can move the AC plug besides the PSU so now your PSU is 40x80x130mm.
You have around 80mm clearance left for the CPU cooler -- aplenty. Especially because you want something without fans as the case airflow should be more than enough. I was thinking the Dynatron K618.
There isn't a lot of space in the case left for hard disks. I am thinking a few mSATA to SATA converters would fit either the wall or the roof: 2*25mm for the fans plus 80mm for the PSU leaves 50mm which enough for something http://www.daidaatdei.com/mz/312-la...-adapter-converter-to-25-35-sata-smallest.jpg like this.
