IDE to Sata
SXT14
hey all,
Well ive ran into a problem, I have an abit ku8 with 2 ide slots, I have 2 hard drives and 2 disk drives using all slots. Any ways i have 2 more hard drives and want to run them in sata so i can utilize them. What is the best way to get ide to sata???
Thanks :confused:
SXT14 said:
hey all,
Thanks :confused:
If what you are saying is that you have 2 more IDE hard drives and want to use them on your SATA ports on the motherboard, then get an IDE to SATA drive adapter.
There's a guy on ebay that sells them for like $10.00 or so with free shipping from Hong Kong. Make sure that you get then right one, there is also one that allows the use of a SATA drive in an IDE port.
