IDE to SATA Converter
It does not say whether it supports 3Gbps signaling, however it doesn't really matter anyway. The fastest PATA interface was limited to 133MBps, i.e. less than the 150MBps that SATA supports.
While I have no experience with this device in particular, if it works as advertised, then you should be all set.
