IDE SATA PATA
  • Thread starter Deleted member 88227
  • Start date
D
Guest
Correct me if I am wrong, but aren't all PATA and SATA devices considered ATA devices, which essentially is an IDE device?
Did some ignorant tech support person give you trouble because you used the correct terminology?
SATA has a AHCI command set or ATA emulation
AHCI supports queues (Native Command Queue) and hot plugging among other features where as ATA does not.
AHCI needs to be enabled on your controller (motherboard or add-in card) and proper drivers loaded on the OS
I have a question that I just thought of.
Is the SeralATA I/II/III speed limitations per link, or per controller? I've always thought it was per link but something I read the other day got me thinking about it.
For example (purely theoretical #'s here), 2 SerialATA II drives each transmit at 300MB/s in Raid 0 (SerialATA II max). Does that give you 600MB/s of throughput, even through a SerialATA II controller, or is it still limited to 300MB/s?
No, controller bandwidth is limited by the bus it is on.
PCI=266mb/s
parallel bus so bandwidth is shared among ALL pci devices
(inc many onboard NICs and soundcards, but thats changing)
PCI-E 1x=250/500mb/s v1/v2
serial communication so bandwidth is dedicated.
PCI=266mb/s
Normal 32 bit 33 MHz PCI is 1/2 of that. pci-x which is 64 bit has several speeds with 266 MB/s being one of them. Also PCI is one direction at a time and 1 device at a time.
Ya, this is the more important one. IDE only allowed 1 thing at a time to access the bus. SATA is more like SCSI in that multiple devices can access the bus at once. The old days of installing from a CD-ROM and it being "read CD, write HDD, read CD, write HDD" are all but lessons from history class.
