I have a DVD/CD player combo, and a 160gb IDE hard drive, is it possible have the CD/DVD player on slave and the HD on Master, or vice versa and still have it work? This is on the same IDE Ribbon.
I've always felt it was best to keep your opticals on seperate cables that your harddrives, especially if you do alot of burning, and that's the way I've always set my gear up. But yes, it is entirely possible. Just set the HD to master and the optical to slave.
