ManyCowsMoo
- Aug 3, 2005
So I think when I was moving this hdd between computers, I used too much force on the IDE connector and I messed up one of the pins. It only comes out 1mm or so while the others come out to the full length. There is some somewhat important data I'd like to retrieve from the harddrive, so how should I go about fixing it? I tried using pliers to pull it out to normal size, but that didn't work.
Oh, I looked up what that specific pin does, and apparently it's used for DMA request.
Any ideas?
Cliffs:
- One pin on the IDE connector of the HDD doesn't make contact with the cable
- Tried pulling it out to normal size with pliers
- What should I do?
- No profit
