upriverpaddler
- Jun 11, 2004
I want to hook up an external drive without going the USB route. I've googled but cant seem to find IDE gender changers or plug mounts. Anybody got any ideas?
OKANG said:Plus, if I'm not mistaken, the spec limits an 80-wire IDE cable to 18" (though I've seen a 24" cable before). A foot and a half isn't very long for an external drive. I agree, firewire or USB is your best bet.
True, since it's for an optical drive you can. The spec for regular 40-wire cables is different than that for 80-wire cables.TheGamerZ said:You can get 36" cables too.
I really don't think that'd work very well. It'd be better to just run a rounded cable out of the computer to the optical drive. Any "homemade" break in the cable isn't going to be very reliable, if it works at all. If you're set on going that route, let us know how it turns out.upriverpaddler said:I just bought a socket 370 flexATX mobo w/ NO ps2 ports and 2 usb ports. I want to put this in a custom box for a childs quasi HTPC / gaming machine that will be highly portable with a minumun amount of extra cabling to have to deal with. I dont want to buy another USB adapter when IDE channels will be sitting idle.
I was thinking I would take an old printer port and carve the insides out. Then pack it full of epoxy putty, Very carefully drill out the layout, then insert some copper pins long enough to stick out both sides. The power from inside the case will be easy to adapt and sleeve w/ the rounded 18" IDE cable i already have. Any ideas or improvements?
Please dont make me use USB!!
lithium726 said:you cant hot swap with an IDE drive... theres really no point to running it outside the case..
Whatsisname said:some controllers you can.![]()
