defakto said:You're pretty close, it's not an access time issue. What's going on is *most* not all optical drives are purely ata33, they are not wired for ata100/133 as most harddrives are. The IDE controller detects if the entire channel, all drives and the cable, are able to transfer at a specific speed. It then operates the channel at the lowest common speed, so with an optical and a harddrive usually, ata33.
