IDE device configuration help
I have an ASUS P5GD1 mobo and got mostly everything hooked up fine except I am getting a little confused on how to hook to up my ide devices properly...I have a primary ide controler supports 2 100/66 devices, 1 primary raid controler , 1 sec raid controller, the raid controller can be setup to preform in ide mode. I have 1 200 gig hard drive and 2 cd-rom drives. My 1st attempt was to put the cd rom drives in the pri-ide controller and put the harddrive in the pri-raid controller...the bios picked up the fact the pri-ide-master/slave where the 2 cd-rom drives, but said nothing about the hard drive so i went into my boot options I could see the hard drive lisied there, also where the computer starts up it does a search for ide devices and the hard drive gets listed as one. When I goto set-up windows the computer can not find the hard drive...What did I do wrong...thank you for the help
later,
whatsgoingon
The IDE RAID controller doesn't appear to be natively supported by any version of Windows, so you'll need to provide the drivers for it during the install (hit F6 at the beginning).
Ok well have the hard drive hooked up to one ide cable and make sure the jumper is set on master. if you do not know what a jumpter i is is right next to the ide cable imput and is useally black with a gold line in it. Read the front of the hard drive and look for the master settings. then do the same on the cd drives set on maset and one slave. And make sure the jumpers are right.
I think the key to this whole set up was just order a S-ATA drive...this will make my life easier...I put the other hard drive in my computer...I was runnning outta of space anyhow..Now I have 120 gig, 160 gig, and 200 gig. That should keep me going good for a while...oddly enough I have the 120 and 160 as primaray IDE, my 2 optical drives and secondary IDE and put the thrid hard drive on the Raid controller...which didn't want to work in IDE mode so setting it to Raid Mode and it allowed to create an Raid array with one hard drive in it. Then windows made do this crazy conversion and formatting...and now its all good.
So whats the point...If you are going to buy a new motherboard get S-ATA hard drives. All the new Motherboard (at least From ASUS) only come with 1 old fashion IDE controller, a bunch on S-ATA hook-ups that can be used in IDE mode...and 2 Raid controllers.
Later,
whatsgoingon
