WillowHawk
- Jul 7, 2004
gots a bad problem dudes...i have a 120 gig stat drive, but the OS is effed up on it...but i have nearly 100 gig of data on it. cant loose it..and odnt worry, lots of partitions, but still, need info on it.. basically it had my OS on it,
now i have a different HD a 40 gig IDE..
i want to use the OS on the 40 gig to access the info on the 120 gig SATA drive...how the hell do you get both of them to work at the same time, without using the 120 gigs OS?
btw, i have an Asus P4C800 deluxe mobo, if you didntknotice my sig
