ID3 Data
Keith130
Is there a programme to complete an MP3's ID3 data by searching a CDDB database? I use dbPOWER AMP to rip my CD's now but what about all my LP's etc I wouldn't like to go through all of them and put in the info.
I believe music match does that but you have to pay a monthly fee. It fills in every field. I really don't know what else is included in subscription. You might try signing up for one day then canceling it. Reply back to this if you do get a sub., I'ld like to know if it's good for anything else. I'ld try it, but Alas I'm a cheapo.
Thanks a lot, I couldnt work out how to use tagscanner so I tried music brainz and it worked really well. Im just away to try the corver art one.
Yea. Tagscanner is kinda counter intuitive.
You can't just load a directory and have it search Freedb for it, you have to select the tracks to make it search for them.
Amazom Image works as a shell extension from windows explorer.
Just right click the folder and select populate covers.
This allows the Foobar cover art "look" to display the album art.
