I'd help fold for ya but... (need help)
type in your log in at that spot (or just hit enter)
then you will need to type in your pw (pw for windows log in)
should be good to go after that
I don't use a password for login, and the client asks for my username again if I leave it blank.
And there is no way to do it without a password? What does it need a password for anyway?
Other will be able to say it better than me, but at the lvl that this program runs at it needs to get at stuff that has admin lvl privileges. (mostly in setting up the smp enviroment that it will run)
The SMP client needs a user password to work.
Otherwise the MPIEXEC and SMPD services it needs wont start.
Give you user name a password.
Then rerun the install.bat useing that password.
Luck ............. :D
The mpiexec.exe need a password to be able to communicate between cores. No way around this unfortunately but you can add a password to your account then setup to auto-logon ;)
You need to have a password for the SMP client to work unfortunately.
Haha, all three of us reply with the same answer at the same time. Losers.
Love it when a crowd flock to a new [H]orde member needing help :p
To setup auto-login.
Start -> Run -> control userpasswords2 ->Ok.
Make sure your username is highlighted and untick the box "Users must enter a name ............". Ok.
Add your password to the next box, Ok.
You will now auto-login with the password.
Edit. I gave more info .......... :p
How come I can't login to this?.
I'm just folding under the name colinstu right now...
You need to register to the site. Then, when you upload the first WU, your stats will appear.
Cool, registered and have the client running.
Can anyone estimate what the PPD would be?
I know... It's just to answer the OP question why he can't login ;)
I know, I'm just saying :D and damn it, my new job has been held off for a little longer, I've got to wait now since they got another applicant and they're interviewing him/her...
/shakes fist
pick me
/shakes fist
go to fahmon.net
and download the program, run fahmon, drag drop directory into the program and it will report your PPD.
I have just gotten stable on the E6420 processor. It's the same card with more L2 Cache. From what I understand that matters. I am getting around 1400 PPD on that right now, without any OC. To get a little more exact you can download and install FahMon to monitor your folding.
Welcome to the best team in all the lands! These guys are really helpful!
...:D and damn it, my new job has been held off for a little longer, I've got to wait now since they got another applicant and they're interviewing him/her...
/shakes fist
pick me
/shakes fist
Hot chick for the win!
sorry Jon! :D
