ID-Cooling T60-SFX mITX case
Phuncz
http://www.idcooling.com/pro_detail.php?id=35
The MSRP is $79.99
Features
  • Pure aluminum casing
  • Compact design to save more space
  • Tower heatsink CPU cooler compatible
  • VGA card supported for best gaming experience
  • SFX Power Supply supported
  • 1×3.5” HDD & 2×2.5” SSD compatible
  • One 92×15mm fan included for better ventilation
  • Color match is specially designed for Gamers
Specifications
  • Model Name: ID-COOLING T60-SFX
  • Overall Dimension: 328×251×160(mm) D×H×W
  • Net Weight: 3.0kg
  • Material: Aluminum Alloy
  • Finish: Oil Painting
  • Parts:
    • Side Panel×2
    • HHD/SSD Rack×1
    • 92×15mm Fan×1
  • Accessories List:
    • Case Body & Parts×1
    • Accessory Kit×1
    • Manual×1
Compatibility
  • Motherboard: Mini-ITX
  • VGA Card: Dual-Slot VGA Card up to 263mm
  • HHD/SSD: 3.5”×1+2.5”×2
  • Power Supply: Micro-ATX/SFX
  • CPU Cooler: Max. Height 125mm
  • Case Fan: 92mm Fan×1
I think it is a quite nice package for the price. Aluminium case with 13.1L volume that allows a dual-slot 10" GPU, nice !
Coming from a tightly packed M1 case, this case seems to 'waste' so much space with the angled front panel and layout of internal components. That said, its certainly offers a different aesthetic look if you don't need an array of hdds and a large cooler with airflow.
What goes in the space above the mobo. 3.5" hdd?.
Yup that and a 2.5" as well.
Seeying that the CPU cooler can be a tower-cooler and the "exit" is right next to it, I doubt watercooling is going to matter much, certainly not worth the added cost over a good Noctua cooler.
Very cool case i like the technical realization by producing the thick parts out of one alu piece. Simple design, hard bents and the color scheme makes this case very impressive. But i like the htpc case a bit more. Bigger air slots are populare like by my b3 and a4.
When does this go on sale? Seen two reviews this week, want to see it for real.
