I have already tried both of those. Hmm, I hope I don't have to reformat.Originally posted by SB22
I didn't find the EXACT setting that does this, but you can try going to the "Tools" menu and down to "Folder Options" then over to the "View" tab and click the "Restore Defaults" button at the bottom. If that doesn't work, there is a "Restore Defaults" button on the "General" tab as well.
BTW i'd suggest using the "Details" view, it's much easier to see everything, and you need to activate your windows
