ICH10R raid5 hangs system when copying files
bradsh
I know raid5 isn't the fastest when it comes to copying. I have a gigabyte ep45-ud3p and 3 1TB drives in RAID5 on ICH10R. I get about ~50 mb/sec writes and ~160 reads according to atto. What I *didn't* expect is that the system becomes *completely unusable* when I copy files to the system drive. I can copy files to my laptop 5400rpm drive at full speed and still use the system just fine, but as soon as I start copying files to my raid array every window on the screen becomes almost completely unresponsive, and they all take turns with "(not responding)" in the titlebar.
CPU usage seems ok (under 10%). Write caching is turned on. Volume write-back cache is enabled in intel storage matrix manager. The advanced cache flush thing in windows is turned off but doesnt seem to make any difference in this issue.
Using windows 7 x64, and it is installed on the RAID5 array (I'm sure i wouldnt get these hangs if it weren't, but this problem SHOULD NOT be happening.)
I looked for a driver update for intel matrix storage but didn't find one for windows 7. I know ICH10R is crap for raid but surely not THIS MUCH crap?? I'm spent all of the money I had for this on the drives and really don't have any left for a controller or SSD windows drive.
Halp :(
I ran into other problems running matrix raid on my ich10r (os half on raid 0/data on raid 5). A drive would desynchronize from the raid 5 portion. I couldn't isolate whether it was a problem with running matrix raid, or running raid 5. I did confirm however that my problems were exclusive to 7 x64, as they did not happen under vista x64. After multiple reinstalls of each to test and confirm, I gave up on it all together and just run a single raid 0 array. Seems like the raid drivers need more time to mature for windows 7....
