I have the new Gigabyte GA EX58 UD5 motherboard which has the ICH10R Intel RAID with 6 ports and the GSATA (Gigabyte SATA) with 4 ports. I am running Windows XP Professional SP3 32 bit version as the OS.
I have the Enhance Technology E8-ML external case which has dual SAS Multilane-4 channels and eight bays for drives. I have a dual 4 port to one multilane cable adapter that fits in an empty card slot. So I run 8 sata cables from the MB to the adapter and attach to 2 2-meter multilane cables which run to the external case.
I am having an issue on the ICH10R ports. I have 4 Baracuda 500GB drives that I have configured as RAID 0 for performance with 128K striping. I use the Intel Matrix Storage Console software to create the volume with the four drives are allocated just fine.
When I format this volume as a drive, it is hit or miss as to whether it will format the space. It will get to 100% formatted and then I get the message "format failed" and a will drive show up with a red status on the Intel Matrix status. Intel Matrix will provide the message that a drive has failed, perform a backup. I have tried using 512, 16K and 64K allocation sizes.
I had gotten it fully formatted one time, ran HD Tach and got a 387 Mb/s transfer rate and was able to capture 15 minutes of 1080p HD capture before I got a "delayed write failure" message. At which point one of the drives in the volume turned to a red "error occurred" status on the Intel Matrix.
I change the registry entry to set the file to FFFFFFFF for the SystemPages setting per MS KB#330174. I no longer get the delayed write failure message. As well I turned off the disk write cache setting for the hard drives as part of another MS KB.
I have removed the hard drive that gets the message from the case and rebuilt the volume using the remaining three drives. The problem seems to follow to another drive. I have swapped the multilane cables. I have moved the drives within the case from the upper four to the lower four. I moved the drive from port 3 since it was getting the error to port 1 and still it fails.
I am now trying to format each drive individually and use them that way to see if any failures occur.
I would appreciate any help on this issue, since I am running out of hardware based troubleshooting steps. Thanks!
