Icemat and Mouses
chkMINUS
Hello Hardocp Forum,
I'm getting a new mouse and mouse pad. I'd like to buy the Icemat 2nd Edition because it would never wear out. I plan on getting it in black (I'm guessing that this color will most likely respond best). However, I have a question. I heard that some mouses don't respond well on this pad. The mouses I'm specifically interested in are the G5, Habu and Deathadder. Do they all work flawlessly on the Icemat 2nd Edition?
Secondly, assuming the above mouses all work, which of those do you recommend? Thanks all and waiting for a response.
I would but they will eventually wear out. Id like to have something that would last longer than 6 months - 2 years. From what I keep reading is that the ratpadz eventually runs thin. Just read about SteelPad though. Going to read up on them real quick.
Damn I didn't know that...that blows :(
Guess I won't buy one then...I was planning on buying it too but I guess when you think about it, it IS silk.
Anywho, I'll just stick to my thermaltake light up pad :D
I'd try the Ratpadz. they DO wear out eventually, but they are not expensive. Plus, teflon mouse feet included free (win !) means less wear and longer life, while providing smoother usage.
We have people that have been using the "XT" design now for over 5 years. The ICEMat is good for wear as long as you like the surface, don't ever move it, and don't ever abuse it. I have seen a few shattered.
The GS might wear out ,they get a smooth spot in them after about a year in my case... but the XT's are almost bulletproof...
Buy one, you wont regret it.
