Ice tea accident
DRJ1014
I was sitting at my desk playing a game on my computer with my nephew. He had a glass of ice tea sitting on the desk and went to reach for it and knocked it over and it spilled over the desk and off the side of the desk hitting the top of my computer spilling through the top fan. I quickly turned off the computer and unplugged everything from the wall, monitor, keyboard etc.
I took it down stairs unhooked my hard drives, video card cd roms and the top fan and set them out and stood the computer up and wiped out what i could on the inside. (only a little bit got inside, most on the desk). I put a fan against the computer and hardware and let it sit and dry for about 1½ hours and went to feel if everything was dry. It was, so i plugged everything back in and hooked my computer up. When I turn on my power switch (the kill switch on the back of the psu for main power) on my PSU my computer turns on for about 8 seconds then turns off. (never done this before)
I can turn my computer on using the front power switch fine and everything seems to be running fine. Im running it without the top fan now going to buy a new one and install it later.
What im worried about is will my computer be fine? Did I do something wrong by letting it dry as if it was water? (the tea was sweetened with normal cooking sugar)
If it's running fine now then you have nothing to worry about, any damage would have been done while the board was wet and running. My guess is that the ice tea must have mostly just dripped onto the inside of the case and not the motherboard itself (otherwise it would have fried instantly). Quickly turning off your system and taking it apart probably saved it.
I doubt you have much to worry about.. I had a similar experience a few years ago, and the machine is still running fine. The only concern I can think of would be corrosion over time.. but I doubt that will be an issue.
If the Tea had sugar in it, you're gonna have to deal with that eventually.
