Megalith
24-bit/48kHz
- Aug 20, 2006
Anyone know if it's possible to convert an ICC profile to a 3D LUT? I did a little search and it seems like the opposite is possible, so I'm hoping it goes both ways.
The proprietary vcgt only contains 2D-LUT information. When talking about display profiles we must distinguish between matrix and LUT profiles. The latter contain 3D CLUTs for transformations from and to the PCS with different intents.No, 3D LUT is included in the icc profile, but the icc profile includes much more information that just the LUT.
What do you want to achieve? If a RGB to RGB transformation is intended you need to specify a source and a target characteristic which are used by a CMM to calculate the supporting points for an accordant CLUT. The color space emulations of some prosumer/ high-end screens work in this way (example). Light Illusion should offer a solution for creating such an 3D-LUT – but I think also Argyll, at least for RGB source and target profiles (not sure if device link profiles are supported). Or do you only want to extract the 2D-LUT vcgt information which is intended to linearize the display in a software calibration workflow?Anyone know if it's possible to convert an ICC profile to a 3D LUT?
See #5: 2D-LUT was a bit misleading: The vcgt contains 1D information for linearization tasks. But that is not the main content of an ICC profile and doesn't enable color space transformations. A LUT profile therefore contains 3D CLUTs for transformations from and to the PCS while a matrix profile describes the actual display characteristic via a simple 3x3 matrix and the trc per channel.Isn't ICC 3x 1D LUTs, not 3D LUT?
At least the MPC HC can internally create a 3D-LUT on basis of display profile and desired target characteristic. For a dedicated RGB to RGB 3D-LUT you should study the functionality of Argyll.I calibrated with a Spyder 4 and have a proper ICC, but supposedly calibration doesn't extend into video playback.
