- Aug 29, 2010
Hi,
I have just installed the ICC profiles downloaded from the Eizo site on my Windows 7 PC running an Eizo S2433WFS-BK.
To do it I've done this:
1. Click the Start button and select "Control Panel".
2. Click "Appearance and Personalization".
3. Click "Display".
4. Click "Adjust resolution", and then click "Advanced settings" of "Change the appearance of your displays".
5. Select "Color Management" tab and click "Color Management...".
6. Check the "Use my settings for this device" and click "Add...".
7. Click "Browse..." and specify the folder where the Color Profile is saved (the CD-ROM drive or the folder where the downloaded file is saved) in the "Look in:" section.
8. Select a suitable Color Profile from the list then click "Add".
9. Select a suitable profile from the list in the "Profiles associated with this device:" and click "Set as Default Profile".
10. Click "Close" to close a menu.
Ok, it's done but I can't see any visible difference nowhere, why?
3. Click "Display".
