IC7 northbridge cooler..
Khyron320
I cant find a northbridge cooler to replace my ic7 max2 northbridge cooler.
The stock one died
then i ordered an mx159 and it worked for 2 months but then the retainer clip broke off...
now i cant find a cooler that uses the same clip as the stock cooler...
anybody know of one?
You can get a Max 3 replacement somewhere....
I'll try to find the link. It's like $6.00.
Or get a thrid party one like me. I replaced the IS7 northbridge heatsink with a passive one from Zalman.
i got a zalman and modded it (with help of kleptophobiac):
cow why dont your just put a wb on it..... looks like you have a silent system... why not add another loop from your cpu to nb to whatever
y not get another mx159?
unless the cooling is bad..
