IC7 NB fan acting up??
masshole
OK, ive had this board for about 10 months. When I start the PC from cold, the NB fan cant get going... it hums loud. I have to open the case and tap it for the fan to get going. If I leave it on too long, it makes this faint whistle sound...
Any ideas what I should do? Call Abit for a new fan (with the possibilty of it happening again in another few months) ot get something else?
Any thoughts appreciated.
The fans bearings are apparently frozen up- so yes, replacement time has arrived. I've never heard whether a board maker will replace a mobo fan or not- because I could see them being classified as ordinary wear and tear items...
Depending on the vintage you have, you may find it better to do a full replacement- the early NB HSF's on those boards had literally no HS and a ton of F... if so.... consider Thermalright's NB-1
Thermalright's NB-1
Ill look into it. Will it still still fit under the ZALMAN CNPS7000A ?
