I searched around a bit but I did not see a similiar problem. First, system specs:
IC7-MAX3
2.8C
One optical drive
One hard drive
3 80mm case fans
1 92mm tornado
430 watt trupower antec
radeon 9700
Heres the problem.. I'm trying to overclock it a bit and seem to be having some issues with low/fluctuating voltages.
The machine is fine at 3.3hz and 1.55vcore. I tried upping it to 3.4ghz and raising the voltage. I increased it, but then I noticed it was not gaining stability along the way. I then checked the realtime voltages and noticed that even though I had set the voltage to 1.65, it was only reading 1.55. I confirmed this through the bios, and mbm. I assume the stability problem is associated with the fact that the cpu is not getting the proper amount of voltage.
The other voltages don't seem too healthy either.
I have the vdimm set at 2.8, it only reads 2.7.
The +5 is 4.89, which isn't too bad.
The +12 is running at 11.67, doesn't that seem low?
The +3.3 is 3.2 which also seems low I think.
If anyone could give me some input it would be great, as this is my friends machine and I have limited time with it.
Thanks,
Matt
IC7-MAX3
2.8C
One optical drive
One hard drive
3 80mm case fans
1 92mm tornado
radeon 9700
Thanks,
Matt
