IC7-MAX3: Replacement for Northbridge Cooler?
Volume
The crappy Northbridge cooler died on my motherboard, and I was wondering, has anyone replaced a NB cooler on their IC7-MAX3? I can't find one with the "hook" setup that the MAX3 uses (as opposed to pins).
I have a IC7-G, and the Swiftech MCX-159 works great :)
Volume said:
Do you think it will fit with my Zalman CPU Cooler in my sig?
I also have a 7000AlCu, and it just barely fits. If you want to use it with the fan, you will have to grind off part of the fan cage. Mine works great without the fan, barely warm to the touch.
The Max3 might be a different story though, I've never used one.
I'm starting to think I'll just throw the MAX3 somewhere in a closet... unless anyone wants to buy one without a NB cooler.
WOW I think I have an idea....?
If I don't do any overclocking and use the heatsink without the fan, you think I'll fry anything?
The fan seems very tiny and I can just attach the heatsink...
But what's puzzling me is... when I took it off, it wasn't the thermal compound I was used to seeing on CPU's like my Arctic Silver 5. It was kinda hard, almost like a dried up glue.
i have one off an msi board that uses the little metal hook assembly it should work
If I do indeed "fry" the Northbridge doing this, will it actually be a small fire in there? I don't know if that's a funny question or not, but I do not want to risk my other components like my x850xt.
"Only problem is that my mobo has a loop lock system for the northbridge fan. That obviously didn't stop me. With a little bit of creative enginering and a trip to Lowes I made it work."
Thanks but I'm not up for modifying anything.
Huh, I just unplugged mine when it started making noise. Been running between 215 and 225 FSB ever since, and nary a problem. I do have an XP-90 over it though.
what kind of person owns an IC7-Max3, but says he doesn't want to modify anything?!?! :confused:
that board screams oc'er/tweaker :p
anyway..if it overheats...your rig will probably just lock up (at least mine did)
It's unlikely you'll fry anything if you're not OC'ing. Actual Intel boards ship with no active heat sink. They're all passive, even on their high performance line.
http://developer.intel.com/design/motherbd/bk/
The thermal compound may be a phase change type. It's dry when cool, but semi-liquifies when hot.
Volume said:
He's saying use epoxy (not sure what that is) and others are saying AS5 is fine....
if it doesnt use the clip assembly thingy he will have to use adhesive thermal compound which is epoxy
When I took off the stock cooler from the MAX3, it looked like epoxy was used although the cooler uses a seemingly sturdy clip mount.
did the fan start making any weird noises before it died or it just up and croaked out of the blue?
The reason I am asking is becaues my NB fan started making a high pitched whinning noise like it wanted to die. I took the fan off the heatsink peeled back the sticker and added 2 very small drops of oil and it never made another noise again.
So that's how you get inside than fan, huh? I'll have to try out that oil stuff if my fanless heatsink shows any overheating.
As for your question, my fan did not die, but rather it started making that loud annoying noise. I figured it was dying, so being the impulsive buyer that I am, I bought a whole new mobo. I returned the mobo just now, and went back to the MAX3 as we speak. I am running it with just the heatsink.
