How the heck do you install the stock Intel HSF on this motherboard? The plastic clips are too big!. I already messed one board up by removing the otes blue cooler thing and dont want to do it again..should i just buy another HSF and use that?
Forget the stock HSF, buy a Zalman 7000 (MUCH easier install and removal).
If you think getting that thing on the board is a pain, wait until you want to take it off... Unless you remove the OTES system, your CPU will likely end up with bent pins.
