IC7-MAX3 Chipset Heatsink Question
Volume
Somewhere down the line, I had to remove my MAX3's chipset HSF. What appeared to be there was thermal "epoxy." That's all I know on that subject - its name.
It appeared to be a glue-like thermal application that was not easily cleaned off by a paper towel, like AS5 would be.
I am selling this motherboard to a friend of mine, and want to make sure that the HSF is properly attached with its thermal needs and whatnot.
So, my questions are:
-What is the best way to clean off this stubborn compund?
-Will this be a good application for reattaching the HSF? I do realize that it is a "permanent" fit. http://www.newegg.com/Product/Product.asp?Item=N82E16835100005
Clean it off with the highest percentage isopropyl rubbing alchohol you can find, and reapply it with regular thermal compound. The adhesive would also be perfectly fine, but not really needed. Heck for $10 you could actually get a much better cooler than the stock one anyway.
The problem with using a regular thermal compund is that the chipset is small and has an uneven surface. Something thicker and maybe stickier would do the job better.
Whle you are correct, the difference is pretty negligable. I remounted mine w/regular AS5, and temps stay pretty cool. I also have a Max3.
Case closed :cool: Thanks for the help bud
