IC7-MAX3 Active Cooling Failing.
Clear
The active cooling heatsink and fan on the northbridge? chip is starting to break down. The fan has become annoyingly loud, and I cleaned it out, but I still think the fan is starting to fail. Anyone have any suggestions as to what I should do? I am going to try to contact Abit, but otherwise I suppose i will have to find a replacement solution that will still fit with my Zalman.
- Clear
My hsf on the Northbridge[the newer style one no less] lasted about 6 months.
I had bought a replacement Abit hsf with the mobo, an IC7 as I heard they suck.
They do and I'm putting a passive Zallman hs on when this 2nd Abit oem repacement craps out.
I only paid $5 for it so no big deal.
There are 2 Zalman passive Northbridge hs to choose from, at least.
Pretty sure they fit with your Zalman cpu hsf installed.
The older gold colored one should for sure.
You might have to glue it on with adhesive though.
Here's a link to one of the Zalmans
http://www.newegg.com/app/viewProductDesc.asp?description=35-118-214&depa=0
here's another one
http://www.newegg.com/app/ViewProductDesc.asp?description=35-118-202&depa=0
My IC7MAX3 northbridge cooler is in the process of dying as well (makes annoying screetching noises and stops/stalls all the time). It's 10 months old almost to the date.
Not sure of the clearance on the Zalman, but with the SLK900U I use, it makes contact with the default NB cooler.
What about the Swiftech MCX159-R... or is it too big?
http://www.modthebox.com/review254_2.shtml
I recommend getting this. The swiftech is nice but the microcool has a much better mounting system.
I concure. That kit uses the same fan on my ThermalTake NB cooler. I have 4 cats, my house is being renovated, dust collects after 2 days on ANYTHING, and mine has yet to even get loud after a year and a half.
That looks kind of large, any idea if that will fit with a Zalman 7000cu sitting right next to it?
I don't know. If you could post a pic of your board with the zalman installed i could tell you.
9mmx19 said
you can buy one at http://www.excaliberpc.com/product_...roducts_id=2469 even though it does kind suck. You might want to give it a try since its cheap.
I'm on my second one since original build 2/1/04.
I didn't bother with the rma thing since the hsf was only $4.99 and I grabbed one a few weeks after my build after hearing horror stories of Northbridge fans falling off into video cards ect.
When this one acts up I'm putting on the little passive Zalman and that problem will be eliminated. I still have the original Intel cpu hsf so the Zalman Northbridge fitting is not a problem.
I think I've read that the newer [blue] Zalman nb heatsinks just barley fit if you're running a Zalman 7000cu or alcu but the slightly smaller gold ones fit no problem.
This refers to IC7's, IC7g's etc.
Both Zalman nb's do the job cooling wise according to reviews over at Newegg.
I got the slightly smaller gold one as I'm only overclocked mildly [2.8- 3.1] and I plan on installing a Zalman 7000alcu soon.
By the way, excaliber is pretty good. No problems the few times I've got things from them.
Thanks for the reply, I am only mildly overclocked as well, so I will probably end up going to that passive gold one, and I'll probably order it off of Newegg once I get to school.
