Ok... here goes, maybe someone here will have some ideas.
I've had my IC7-G for almost a year now. Last night I upped the bios from v23 to v27, and swapped CPU's from a 3.2C to a 3.4E, and to put the computer into a different case. After that was done, everything seemed to be working fine.... until I plugged in my printer (USB 2) and I got that fun little message in windows about a High Speed USB device being plugged into a Non-High Speed USB Hub. I then checked all the usb ports with the printer, and got the same thing.
I checked through the bios if there were any settings to enable/disable USB2, but I didn't see anyting (doesn't mean I couldn't have missed it tho)
I removed all the USB devices in the device manager and shutdown/restarted the PC hoping that windows Xp would re-detect the USB stuff correctly, this didn't seem to work either.
I even got on Windows Update
with very faint hopes that it would tell me there is a USB driver to install.
Any help would be appreciated......
Thanks
Laban
Thanks
Laban
