IC7 - Advice need for SATA & IDE Config
morpheus9394
Just installed my first SATA motherboard and I need some help with the config of my several HDDs and CDROMS.
This is my current config:
SATA HDD as my Boot Drive - Windows XP Pro SP1, on SATA1
IDE HDD ON IDE1 - Drive set to cable select and is on the master part of the IDE Ribbon
CDROM & CDRW on IDE2 - CDROM Master, CDRW Slave
In bios the following has been auto detected:
IDE1 Master - IDE HDD
IDE1 Slave - None
IDE2 Master - CDROM
IDE2 Slave - CDRW
IDE3 Master - SATA HDD
IDE4 Master - None
IDE & SATA Chips are both enabled, SATA in IDE mode NOT raid.
SATA in Enchanced mode
SATA Raid chip enabled but not install in Windows (need to install tonight)
The SATA drive is first in the boot order.
This config works well and all my drives and appearing in windows and are running at their correct speeds (Multi DMA 5 for the HDDs and Multi DMA2, i think, for the CDROMs)
The only weird thing that sometimes happens is that on a reboot, the SATA drive is sometimes lost in bios and not found during the post process, unless you soft reset. It will then be found again but the boot order will change making the IDE drive first.
Not a major problem but a slight pain leading me to think I have not configured the bios properly.
Any advice on my config, epespecially with regards to speed and stability would be appreciated.
Thanks.
I am using ID 1.9
Its the latest, I think.
Just tried changing the cable for the IDE drive, so that is was on the slave part of the ribbon but still get the problem on reboot but not all the time.
Weird.
2.0 is the latest.
http://forum.abit-usa.com/showthread.php?s=&threadid=35203
Read and upgrade if you wish.
I have sort of the same setup as you do albeit with different brand drives. Here is the setup:
Samsung SP1614C SATA HDD as my Boot Drive - Windows XP Pro SP1, on SATA1
DVDROM & CDRW on IDE2 - DVDRIM Master, CDRW Slave
I have no issues with boot up, shut down, nor speed. I did have a problem with speed at first, but a quick run of Bootvis and everything was in order.
Make sure you enable IDE Bus Master in the bios. It's off by default. It helped solve a lot of problems I was having getting a SATA drive to work with a PATA drive.
Thanks for the info.
Updated the bios to ID2.0, cleared the CMOS and re-applied to bios settings (also turned on IDE Bus Mastering)
But unfortunately I am still getting the same problem. Very weird.
It seems like the SATA and the IDE HDD are having a little gang fight. My western Digital IDE drive obvious does not like being moved to second in command and keeps pushing my shiny new Seagate SATA drive off the bios.
But if I do a hard reset everything is works fine.
Any other ideas??
