IC-7 Max3 questions...
ZeroC00L
Here's my question... I just bought an IC-7 Max3 and I plan to build a new comp this summer. Here's the list...
-PC Power & Cooling 510 Deluxe
-Intel Pentium 4 3.2 GHz 800FSB
-Kingston 512MB PC4000 X2 (already purchased from Best Buy at $117.00 each!!)
-WD 160GB Hard Drive SATA
-WD Raptor 10K 36.7GB Hard Drive in RAID 0
-CoolerMaster WaveMaster in Black with window
-ATI Radeon 9800 Pro (from my current Dell Dimension 8300)
-SoundBlaster Audigy 2 ZS (in my Dell)
-CD/DVD-RW...blah, blah, blah...
Does N E 1 have any of these components on the Max3? Especially with the 510 Deluxe, are there N E issues? I know the Max3 is power hungry... will it be enough? I have also noticed the OTES is pretty close to the CPU Cooler brackets, so what is the best cooler for the job? I am using my Radeon seeing is how the R420 and NV40 cores are coming soon, hopefully!
Im sorry for all the questions, but this is a big purchase and I dont want N E problems due to lack of research or resource... Thanx in advance!!
Hmm, I don't have any of those specific components on my MAX3 but what I'm running is mostly in the same class and I don't have any problems. You've selected good components and it should be fine. For reference here's my setup:
IC7-MAX3 (of course :) )
P4 3.0C
2 x 256MB Mushkin PC3200 Black Level II 2-2-2-5
PNY GFFX 5700 Ultra (Upgrade soon to a GFFX 5950U or NV40)
2 x Seagate Barracuda IV 80GB SATA (RAID 0)
2 x Maxtor 40GB ATA133
Toshiba 8X DVD-ROM
Sony 32X CDRW
Soundblaster Audigy (W LiveDrive from my old Live! Platinum)
Coolermaster Praetorian
Antec 400W SmartPower (Soon to upgrade to a 550W TrueControl)
The only thing you might consider changing is the Wavemaster to a Praetorian or a Lian-Li. The Praetorian is less expensive, has the same internal layout as the Wavemaster, and better airflow. It doesn't have the fancy front, but the styling is still nice, and I always find a door to be a pain in the ass anyway. Either you're constantly opening and closing it, or if you leave it open, then what's the point of having it? I put the aftermarket coolermaster aluminum bezels on mine and silvered my floppy drive and it looks very sharp.
Looks good. I'm sure that power supply will serve you well. Just remember to double check the jumpers on all of your hard drives. I couldn't get my Max 3 to recognize my raptor, and I tried for 2 days before I figured out that the jumper was set to power-on standby mode the whole time! :eek:
VayVay, did you have any problems with your Max 3 and the Mushkin RAM that you have? I went through two sets of PC3200 2-2-2 Special and got nothing but problems, and I'm not the only one. I already RMA'd for some Corsair XMS anyways, but I'm just curious.
HitMan: The only problem I had was that it wanted to autodetect the RAM as 2-3-2-6 for some reason, but I just manually put it at 2-2-2-5 and it has worked flawlessly. I don't run overcloced most of the time but I have experimented a little without incident.
Oh, and mine is the old Level 2 Black that they replaced with the 2-2-2 special, so that may be the difference. I'm kinda bummed because I want to pick up another 512 or 1gig and I'm having trouble finding the old stuff. :(
